Aft fuselage belly skin on a Legacy Sonex
Posted: Fri Mar 04, 2022 12:18 am
by karmarepair
Is it easier to work from the fwd end aft, or the other way round?
It looks like a PITA to get at the nut for the two machine screws at the tail via the inspection ports, but it also looks like a PITA to line up the little bitty spacers up forward while sandwiching the aft skin between the forward skin, the splice plates, and the aft spar carry through.
How did you do it?
Re: Aft fuselage belly skin on a Legacy Sonex
Posted: Fri Mar 04, 2022 7:14 am
We (my son & I) did the aft skin from front to back. first lift tail to comfortable hight. Place something on the floor to protect aluminium skin & you.
Start from front, as you work back, lower tail keeping work area within comfort zone.
Good luck!
