Alternator Replace
Posted: Fri Jul 28, 2023 8:45 am
by Cpt.tidy
Just had my second alternator failure in less than 50 hrs. The first failure was caused by an oil leak that got into the stator. That was a legitimate failure. However; the second was just an outright failure. Sonex stators are very pricey. My guess is this is a generic part as most of the sonex parts are. Just looking for cross reference part number that will work. Any ideals.
Regards,
Jerry
Re: Alternator Replace
Posted: Sat Jul 29, 2023 2:04 am
by rizzz
Cpt.tidy wrote:Just had my second alternator failure in less than 50 hrs. The first failure was caused by an oil leak that got into the stator. That was a legitimate failure. However; the second was just an outright failure. Sonex stators are very pricey. My guess is this is a generic part as most of the sonex parts are. Just looking for cross reference part number that will work. Any ideals.
Regards,
Jerry
Don’t quote me on this, I could be wrong, but I remember reading somewhere the alternator is a Kawasaki brand.
Might be worth searching though their catalogs and see what comes up that looks alike.
Posted: Sat Jul 29, 2023 5:34 am
by Cpt.tidy
Thanks, I’ll check it out.
Posted: Sat Jul 29, 2023 9:50 am
by Dave Wolfe
The voltage regulator appears to be a kawasaki part Im not sure if this is the right one:
21066 7011 voltage regulator
Also be warned aftermarket voltage regulators can cause issues. The aerovee stator resembles the jabiru stator, and jab stators fail with the B&C regulator designed for rotax engines. I believe the B&C is a “shunt” type. I dont recall anyone using the B&C with the aerovee and if it was successful or not.
Posted: Sat Jul 29, 2023 4:01 pm
I would suggest that when & where you can you should support the factory. They have the correct, tested parts, that are exact replacements for your alternator & regulator. We need them to be here for a long time so give them your business when you need parts.
3.0 Corvair/Tailwheel
Posted: Sat Jul 29, 2023 11:42 pm
I’d be interested to learn more about this failure. Until your failure, the only failures I’ve been aware of has to do with screws backing out and cutting through the stator windings (addressed for quite a while with a Service Bulletin).
How did the oil leak damage the stator? I would have thought it would be pretty impervious to oil.
Also, the wire is relatively low voltage and if I remember correctly the coils are all cast inside resin, so it’s hard for me to imagine how it can fail so quickly. I assume you measure an open circuit when probing the leads with a multimeter?
I’m suspicious there might be something else going on with the electrical system that’s destroying the stator. Unless you are pretty convinced the oil leak caused your first failure, I’d be suspicious of another underlying issue like the voltage regulator and the rest of the electrical system. Is it possible there’s some unintentional way to draw more than 20A through the alternator?
Posted: Sun Jul 30, 2023 5:40 pm
daleandee wrote:I would suggest that when & where you can you should support the factory. They have the correct, tested parts, that are exact replacements for your alternator & regulator. We need them to be here for a long time so give them your business when you need parts.
I totally agree with this statement. Sonex has very good after market service and I would love to see that continue. Support them where you can especially if you don’t have the freight issues of shipping to Australia or other far away lands.
Posted: Tue Aug 01, 2023 9:17 am
by Cpt.tidy
Thanks for the great input. After further testing i have determined that is in fact a regulator failure. All of this was preceded by an engine failure at 276.0 hour requiring a forced landing. All turned out well. However I was surprised the engine failed with such a low numbers of hours of usage.
The number four cylinder valve broke in the middle, damaged the head, went thru the piston, and punched a hole thru the case. I’ve since rebuilt the engine and that was when i encountered the charging problem. But, I think I have that solved.
I am however disappointed that the engine failed with such a low number of total hours. I am a licenced FAA mechanic and maintained the aircraft to the highest standards. This has created a trust issue with the aerovee engine.
As to first stator failure, oil seeped into the stator assembly causing it to short out. You could definitely smell it and see the results on the instruments.
Thanks for all the input.
CPT Tidy
