AN525 screws: suggested drill bit?
Posted: Fri Mar 13, 2020 2:04 pm
by SP1
I’m about to put the AN525-10R screw hole through the longeron and aft fuselage skin (SNXB). Was wondering what others have used to drill the hole? Instructions say to get a nice tight fit. Thanks
Re: AN525 screws: suggested drill bit?
Posted: Fri Mar 13, 2020 3:35 pm
by lgsievila
Hi Sam,
AN 525-10R screws are 3/16" (.187). To get a tight fit you consider an undersize drill bit ,#13 and then use a 3/16" straight reamer. Not sure of the exact location you are talking about but if the screws are in shear, you don’t want any slop at all in the hole.
Posted: Fri Mar 13, 2020 3:48 pm
by SP1
Thanks Loren,
I’m glad I asked! Still trying to wrap my head around the nomenclature, and I the hardware kit hasn’t come in yet.
This is for the holding the front fuselage to the rear fuselage via some hefty plates (F25 page, part F26-06). Hardware kit hasn’t come in yet but I’ve got everything lined up.
Posted: Fri Mar 13, 2020 6:23 pm
lgsievila wrote:Hi Sam,
This is what I did as well. Don’t go straight to it with a 3/16" drill bit, it will probably end up oversized.
Same goes for AN4 bolts, use a “D” bit, not a 1/4" bit.
Posted: Fri Mar 13, 2020 7:22 pm
Back in the old days before reaming was the new norm. A good correctly sized drill was the recommended way…With thick material I found 9 times out of 10 ten a 3/16 bolt would still be too tight to go into a well drilled 3/16 hole without further clearing.
I’m not saying dont ream, just saying its not absolutely necessary.
The main thing either way is to get the hole perpendicular. I guess a reamer may help save the with a crooked hole.
Steve
Posted: Fri Mar 13, 2020 10:28 pm
by lgsievila
Ryan-you are correct, any time you want a body fit bolt/screw you should drill undersize and then ream to the correct diameter. Sonex 892, I would be concerned about the 1 in ten times your drill action is oversize. When you use a reamer the attachment hardware acts as a dowel and that is what you want in a shear application-you don’t want anything to move. That is also why you never use a threaded fastener in a shear application-reference Service Bulletin SNX-SB-008.
EAA Tech Councilor
Posted: Sat Mar 14, 2020 3:09 am
lgsievila wrote:Hi all,
EAA Tech Councilor
All due respect Loren. I didn’t say I had 1 loose hole in ten. I said 9 were too tight to insert the bolt without further clearing. If a sonex build is your first rodeo it is probably advisable to use a reamer.
Posted: Sat Mar 14, 2020 10:08 am
For critical wing and tail attach bolts I definitely drill undersize and ream to a tight fit. For the fuselage gussets I just did many steps in drill size and finished at nominal for a snug fit and a round hole. I always drill in many steps for bolt holes, otherwise they end up triangular.
Posted: Wed Mar 18, 2020 1:07 pm
by SP1
Thank you all for your thoughts. I’m hearing that I should drill with an 11/64, then finish off wiht a reamer.
