Summer temperatures and cooling
Posted: Tue Jun 06, 2023 9:37 am
As the calendar rolls around to summer in my first year of flying, I’m starting to have issues. Pattern work with 2 people above 80F isn’t working out. Oil temps are getting to around 230F and I got CHTs approaching 400F for the first time. Plus it’s so hot under the cowl that the burps on the ground are ugly.
I’ve just ordered a set of B model outlets and are going to add them to what I already have.
Re: Summer temperatures and cooling
Posted: Tue Jun 06, 2023 3:43 pm
Hi Brian
Looking forward to your cowling exhaust mods documentation. I’m planning to start with only these vents, hoping the lower pressure at the fuselage sides will lead to more airflow with less drag.
Gordon
Posted: Tue Jun 06, 2023 6:20 pm
GordonTurner wrote:Hi Brian
Gordon
Hi Gordon,
Just a heads up with the Corvair in a Sonex airframe as they tend to cool very well. My summer CHTs (under the plugs) read about 225ºF. Oil temp (with stock GM 12 plate cooler) runs 200-210 in the summer months. I did get it close to 230ºF in a steady climb with two on board. I use Rotella 15W40 and have seen evidence that it is not harmed at those temps at all.
I asked Dan Weseman about the cool temps with my Cleanex and he asked what problem I was trying to solve. 8~) He reported his Cleanex was the same way with the cool CHTs.
Posted: Tue Jun 06, 2023 11:10 pm
by Rick524
Hi Bryan, I made side vents for my ‘A’ Sonex on my cnc router. I can send you the Vcarve files if you are interested.
Rick
Sonex 524
Posted: Tue Jun 06, 2023 11:25 pm
Rick524 wrote:Hi Bryan, I made side vents for my ‘A’ Sonex on my cnc router. I can send you the Vcarve files if you are interested.
Rick
Sonex 524
Rick, sounds good thanks.
Posted: Wed Jun 07, 2023 12:40 am
by Rick524
i guess the best way to send the files would be via email, if you want to pm me your address.
Rick
Sonex 524
Posted: Wed Jun 07, 2023 12:44 am
by Rick524
Got it, should have checked the pm before I answered…duh.
Posted: Wed Jun 07, 2023 2:05 am
by AlexZ
Above 80F the Aerovee powered Sonex is basically a one seater. Flying with 2 onboard is possible, but only with a shallow climb out. Don’t do pattern work. Temps will built up and ruin your cylinder heads.
I designed side vents as sheet metal.
Can send drawings.
Posted: Wed Jun 07, 2023 9:18 am
Got the files, thanks Rick!
Alex, looks great, I’ll pm you my email address.
Posted: Sat Jun 10, 2023 6:07 pm
Had some email exchange with Mark Schiable. He did not recommend running both A and B model outlets together. I bought a set of B outlets from Sonex but am holding off.
One other thing, my oil pressures have always been high - like 90-100 psi at startup depending on temp. Cruise was 70 psi on my long Tennessee trip. The Aerovee manual says 40-50 in cruise. My understanding of the VW oil system is that low pressure allows oil to go through the cooler, and maybe I’ve not been getting that. So I took out and polished both plungers, then cut a half loop off the pressure regulation spring. That is the short one near the back of the engine, away from the oil pump. On the last flight I saw 60-65 psi and ~220F. I’m going to cut off another half loop.
Posted: Sun Jun 11, 2023 1:16 am
Bryan Cotton wrote:Had some email exchange with Mark Schiable. He did not recommend running both A and B model outlets together. I bought a set of B outlets from Sonex but am holding off.
All -
For those not on the Facebook page, I performed the first flight of my Legacy Sonex with an AeroVee Turbo & “B-model” side exits (on a Universal cowling with no exhaust tunnels) back in mid-May. I found that the engine did not cool AT ALL with just the side exits once I went to takeoff power. I have since added a 13" x 5" opening in the bottom cowling at the rear with a ~1.5" deflector (angled downward from horizontal by 30 degrees). I hate the idea of the extra drag of the deflector, but this bottom exit has taken my CHTs from ~450 down to ~380-390 as long as I keep the MAP below 31" after about 90 seconds of takeoff power (40" MAP). This is still not ideal, but way better! And that comes after I tried redoing my baffle seals and other tweaks to ensure I was getting good air to the upper plenum.
Per suggestions from Sonex I’m going to try taping over the side exits on an upcoming flight to see how that changes lower cowling airflow. I may also temporarily mount deflectors to the front of the side exits to see how that changes drag & cooling.
I am still dealing with some pretty insane temps in the rear of the engine bay. Its causing some vapor-lock issues on landing & taxi after flight (even with firesleeved fuel line and aluminized fiberglass heat shielding over the fuel flow sensor). The AeroInjector itself is skin-blisteringly hot after flight and I’m worried the heat is going to kill the firewall-mounted items like my engine monitor RDAC, voltage regulator, etc. I am debating whether to mount a NACA scoop on the side of the lower cowling with a blast tube generally directing air along the firewall; or whether I should punch a small hole in the rear engine baffle and use a short bit of SCAT/SCEET tubing to achieve the same effect. Either one potentially disrupts the pressure differential between the upper plenum and lower plenum; but I don’t see a better way to get more airflow to the firewall-mounted items and keep that area cooler. The engine bay with the Turbo is just tight and that area experiences low airflow plus a lot of radiant heat due to the turbo (even with the SS shield looped around it).
Bryan - Regarding oil pressures: If you look through my older posts you’ll find an epic one about my oil cooler blowing out during early ground runs. A lot of the oil pressure sensors top out at 80-100 psi so if you see those readings beware that you could actually be way higher than that!! When mine blew out (probably around 150 psi even though it only read 90 on the gauge), the pressure-relief plunger had gotten stuck at the very top of its travel. During assembly I could slide it smoothly in its bore on the bench, and thought it was hitting the end of its travel. But in running conditions it was able to push up a little further and get wedged.
So make absolutely certain when you polish the plunger that it really is making it to the end of its travel in the bore without any impediment. I polished the plunger and then also wrapped some fine-grit sandpaper around an appropriately-sized dowel and did a light bit of polishing/sanding to the bore (and then carefully rinsed it out thoroughly with 90% isopropyl alcohol to ensure I wasn’t putting a bunch of metal grit into the oil system). Now with Penngrade 15W-40 I see ~45-55psi in flight and ~10-20 psi on the ground.
Hope this info helps,
–Noel
Sonex #1339
Posted: Sun Jun 11, 2023 2:25 pm
Thanks Noel! I did take another shot at polishing the plunger. To do this, I found that a 1/2" metal rod was a slip fit inside the plunger. With a little blue tape on the end it stuck pretty good. I chocked up the rod in the drill press and polished with scotch brite. Then I chocked it up in a hand drill and worked the plunger up and down in the case. Seems pretty free to me. I also shortened the spring by another half turn. I’ll see what happens next. I did do a ground run and the pressures seemed a little lower. Need to get out and fly it again.
Posted: Mon Jun 12, 2023 9:34 am
Until I cut a NACA scoop in front of the air cleaner, my engine never ran well at all. With the MGL efis I put thermocouples all around in the engine bay and temps were 150 in the carb throat. Now my carb temps are a little over ambient…depends on climb angle.
Posted: Mon Jun 12, 2023 10:06 am
Thanks Bill, great picture. I am planning on some fresh air for the induction system as well. I will not pressurize the system as that messes with the aerocarb mixture.
Posted: Mon Jun 12, 2023 10:27 am
by tom.corso
Bryan / All,
As I have done my “tinkering” on my 80HP Aerovee, I have gotten to know some folks with considerable expertise on air cooled VW engines. One of these guys is Prescott Phillips and he actually “wrote the book” on rebuilding these engines. He and others convinced me that 40 - 60 psi oil pressure is perfect. On the low end, an idling engine with hot oil will do just fine with 5psi or less oil pressure. The VW Bugs low oil pressure light came on at 2psi. Running really high oil pressures might contribute to more leaking. For those running external oil filters, an excellent idea, 100psi puts stress on the lines and could even burst the lines or the oil filter. The recommendation is to run the stock parts originally supplied by VW. That is what is in my engine. With warm oil and rpms of 1700 or above I have 40 to 60 psi. Saturday after flying in 85 degree air temp and 80% humidity, I had 15 to 17psi at idle with an oil temp of 165 degrees.
While I am up here on my soapbox, given that running 80 or 100 hp in these engines produces a lot of heat, and that the oil circulation is an important part of cooling “air cooled engines”, does anyone really think that an oil capacity of less than 3 quarts is a good idea? Adding high capacity oil sumps and external oil filters adds weight and complexity, but it might help with cooling and longevity. Anyone have thoughts on this? I tried to paste a scan of the back cover of the book in this message, but I don’t think it worked.
Tom
Posted: Mon Jun 12, 2023 10:38 am
Not sure how to post photos on this site, but while my CAMit cylinders were off to the UK to be fitted with forged pistons, I made a modification to the cooling air outlets on my A series Sonex. Cut the openings about 5" forward and inserted ramps that slope down to about 2 + " below the cowl at exit. seems to have greatly increased cooling. Have photo showing one side original and one side converted. I thought the small lip that Sonex called for at forward end of the openings looked like turbulence generators that would reduce to ability of air moving past the outlets to help draw air from within the cowl. The modification seems to have helped a lot, may even have to install part of my winter baffle kit for all but hot summer days.
Posted: Sat Jun 17, 2023 7:27 pm
I have dropped my cruise oil pressure to about 60-64 but no big change in oil temperature yet.
Next thing to try is to open up the exits from my oil cooler plenum. Before:
oil cooler plenum exit before.png (915.79 KiB) Viewed 9137 times
The openings were pretty small before. Now I’m more than double, by my eyeball estimate.
oil cooler plenum exit after.png (727.94 KiB) Viewed 9137 times
Posted: Mon Jun 19, 2023 8:03 am
So I have now flown three times with my improved exits - and the temperature is 10F warmer. Any thoughts? I am going to tape it back up to original or maybe slightly less and see what happens.
Posted: Mon Jun 19, 2023 9:12 pm
by n502pd
The lower lip on the bottom cowling is called a ‘seaplane lip’, and is indeed used for enhanced engine cooling. I put one on my plane after opening the overall size of the opening by 25% on all dimentions. I am using a bottom cooler that is, probably, 100% bigger than the top cooler, or maybe a bit more. Its hot here at times and I have not seen oil temps higher than 210 deg durring break in, and less than that after.
A small thing to consider, and I say this with sinserity, " its easier to control over cooling, than under cooling’. In winter, to get temps off the peg, I made cowl opening restrictors to limit the overcooling on cold days. Just a thought!
Posted: Mon Jun 19, 2023 11:07 pm
Thanks for the thoughts Joe and guys.
One of my former Sikorsky coworkers has a Mooney. Much different animal, I know. But they found that the airflow through the cooler was backwards from expected, so apparently the area they thought was low pressure was actually higher pressure. They tufted it and put a camera on it. I have a hard time understanding how the pressure behind the engine could be higher than over the engine, but if that was the case I could be heating my oil from the hot air in the bottom.
Posted: Tue Jun 20, 2023 12:29 am
by 13brv3
Do you have a manifold pressure gauge, or at least an option to connect a MAP sensor to your engine monitor? If so, that makes a dandy cowl pressure sensor.
Posted: Tue Jun 20, 2023 9:29 am
13brv3 wrote:Do you have a manifold pressure gauge, or at least an option to connect a MAP sensor to your engine monitor? If so, that makes a dandy cowl pressure sensor.
I don’t. I do have some old Motorola pressure sensors and a raspberry pi, but I’m not sure I have the ambition.
Posted: Tue Jun 20, 2023 1:44 pm
by 13brv3
I bought one of these a while back to try to measure differential pressure, but I’ve had that same ambition problem. I also just don’t have a good way to run the hoses through temporarily.
https://www.amazon.com/gp/product/B099ZYCV1L
Posted: Tue Jun 20, 2023 10:18 pm
Rusty, run your lines out an air vent and then up through the cowl outlet or inlet. Just use the good duct tape. That’s out of the Sikorsky flight test playbook.
So in the name of science, I taped over both oil cooler plenum exits inside and out. Left the plenum cover off and went flying.
Last Sunday we stabilized at 219-221 F in cruise. Tonight after 12 minutes of flight, including a climb to 2500’ it was 226 and slowly rising. We did a simulated engine failure as we stayed right over the airport.
So I’m calling that one a fail. Onto the next science experiment. Stand by.
Posted: Wed Jun 21, 2023 10:43 pm
I mounted a little piece of pipe into my exit plenum and secured it for a test flight. The idea is to pull the air out to a separate external exit.
air goes in here.png (549.41 KiB) Viewed 8706 times
air comes out here.png (509.95 KiB) Viewed 8706 times
This aluminum tube is sealed to the plenum with metal tape. I used a little shop vac hose for a temporary test.
hose through bottom of cowl.png (709.7 KiB) Viewed 8706 times
I even used the hose end that plugs into the vac as my exit.
shop vac pipe.png (511.83 KiB) Viewed 8706 times
Initially it seemed like I had a winner. Temps looked really good during climb. They were slowly going up towards 200, it was 90F out, and I was at full power and 80kts. Leveled off and after a bit it seemed the rate of increase was going up even though I was at cruise power and 100kts. So I landed, and found the hose had softened, rested on the exhaust pipe, melted and sealed itself.
Based on my initial positive results I am pursuing this further. The shop vac hose, besides not handling the temperature, is only about 1" ID and corrugated. It was too long also. So I’ve got some 1.75" scat tubing on the way. I plan to do this right and try again.
Why am I messing with this approach? My CHTs are almost always under 300F. I don’t want to screw that up. The only time I went over 400 was a month ago, doing patterns in the heat. The oil got hot first.
Posted: Thu Jun 22, 2023 11:46 pm
Ok, getting serious about this mod. I’m no longer baffled on what to do.
baffled no more.png (582.94 KiB) Viewed 8647 times
Posted: Sat Jun 24, 2023 5:42 pm
I’ve got the rivets drilled out of my baffle. It’s all apart on the bench. I used it to make a paper pattern. The black outline is where the opening currently is. The green outline is how far I can go if I ignore the rivet line.
pattern clecoed.png (677.63 KiB) Viewed 8581 times
Here I have marked out where my 1.75" tube needs to go.
pattern for locating pipe.png (562.55 KiB) Viewed 8581 times
Posted: Mon Jul 03, 2023 9:33 am
Here is a progress update. Tubes riveted onto the baffle:
tubes riveted to baffles.png (647.23 KiB) Viewed 8392 times
Baffle back together and clecoed to the case:
baffle with tubes in place.png (601.25 KiB) Viewed 8392 times
This is a mockup reverse scoop. It’s a box constructed in two pieces. The flanges go corner to corner and will mount inside the cowl with the ramp sticking out.
mockup reverse scoop.png (698.57 KiB) Viewed 8392 times
I am going to try one hose and outlet first, and record results. Effectively I’m just increasing outlet area by about 2.5" per scoop.
Come wintertime, I see cabin heat experiments in my future.
Posted: Tue Jul 04, 2023 5:36 pm
Two reverse scoops.
two reverse scoops.png (638.01 KiB) Viewed 8279 times
Posted: Tue Jul 04, 2023 10:22 pm
I still need to trim the hole before I can rivet it in.
outside view reverse scoop.png (500.02 KiB) Viewed 8254 times
inside view reverse scoop.png (507.74 KiB) Viewed 8254 times
Posted: Wed Jul 05, 2023 9:41 pm
Hose on the top:
hose top connection.png (744.99 KiB) Viewed 9405 times
Hose on the bottom:
I’m close to reassembly. Looking forward to flight test.
I’ve also got another set of CB Performance oil control springs on the way. Thanks 429TB for the info.
111-115-421a Oil Relief Spring - OEM
111-115-425a Short Oil Relief Spring - OEM
~$12 shipped.
Posted: Thu Jul 06, 2023 9:08 am
Very late seeing this thread. I have top mount oil cooler with the Sonex supplied baffling. Unless its really hot outside, I duct tape some of my oil cooler to prevent over cooling
Posted: Thu Jul 06, 2023 9:13 am
Here is the reverse scoop installed on the right side. I’m not doing bodywork and paint until it is proven. The exit was initially ugly aerodynamically. I had to taper the cowl to a knife edge and then put a piece of 0.016 over it. I actually like this part.
scoop installed.png (615.92 KiB) Viewed 9358 times
Posted: Thu Jul 06, 2023 9:14 pm
~$12 shipped.
What is the benefit of these springs?
Posted: Thu Jul 06, 2023 9:32 pm
pfhoeycfi wrote:What is the benefit of these springs?
See thread:
viewtopic.php?f=7&t=7312
Reader’s digest version:
The VW oil system has two spring/plunger systems. The one at the end of the line regulates the overall oil pressure. When the pressure gets low (which happens as the oil heats up) the one at the front of the line diverts oil to the oil cooler.
So, like me, if you have high oil pressure you may not be getting enough oil flow through the cooler.
My pressures had been about 70 psi in cruise, instead of 40-50. I shortened the spring in the back of the motor and got it down to 60ish. New member 429TB bought those springs and had good results of lower oil pressure and temperature. It’s a really easy thing to try.
Posted: Sat Jul 08, 2023 9:32 am
Fyi something to consider. I measured the cooling air PD across the engine from above the engine to near the right side exit.
The values were…at IAS
2" at 65 mph
2.5" at 75 mph
3" at 85 mph
3.5" at 95 mph
4" at 100 mph
4.5" at 110 mph
5" at 120 mph
I used an old school manometer and my IAS is what it is. The values are rounded. Another airplane will likely have different results. But its a baseline. Attempts at flow improvements will yield greater (hopefully), the same or lower DPs at these speeds. I’ll likely confirm the numbers before I make any changes. I’m also going to check the DP across the oil cooler.
Posted: Sun Jul 09, 2023 12:01 pm
Peter, great data, thanks for posting!
I did flight test my oil cooler extraction scoop today. There was slight improvement - oil temps around 215-217 in cruise.
I really want to get my oil pressures in spec. This should be 40-50 psi per the Aerovee manual. I believe that is a key part of cooling as the oil flow through the cooler is a function of pressure dropping as the oil warms up. That is my next step. I believe my plungers & bores are good as I have had them out a few times and checked/polished them. My new springs should be here next week. My oil pressures had been running at 70psi in cruise, and 60 after I shortened the spring.
If the new springs fix the oil pressure but the temps are still high, I’ll add the second reverse scoop. Right now I have the left side exit tube taped over and just have the one hose on the right side.
Posted: Wed Jul 12, 2023 10:09 pm
I’ve installed the springs and see at least a 10 psi drop for startup and ground running. We had neither weather or daylight to fly it.
My pressures had been 70 at startup and 60 at 200-220F oil temps in cruise. Startup tonight was 60 psi and stayed there for a 5 minute ground run, including WOT at the end. Max oil temperature was under 110, so I believe that will be a lower pressure as the temperature goes up.
The new oil pressure spring is noticably softer and about the same length as the original chrome looking spring I trimmed. New oil cooler spring is about a cm longer and similar stiffness. I’m cautiously optimistic.
Posted: Fri Jul 14, 2023 12:15 am
Too many tornado warnings to fly this evening. Hope I can test my new springs tomorrow. I made this cartoon of the VW oil system:
Posted: Fri Jul 14, 2023 12:03 pm
I believe the oil that has passed through the cooler gets directed into the oil galleys and not directed to the sump.
Also, now when I read your posts, I hear Mel Blanc’s voice. .
Posted: Fri Jul 14, 2023 12:38 pm
Area 51% wrote:I believe the oil that has passed through the cooler gets directed into the oil galleys and not directed to the sump.
My research had indicated otherwise but could be wrong. So does all the flow go through the cooler once the pressure drops?
Edit: you are right, it rejoins the galley before the pressure regulator.
https://www.thesamba.com/vw/forum/viewt … p?t=280293
Posted: Fri Jul 14, 2023 7:47 pm
Improvement. 214-215 stable at 87 ambient vs 219 and climbing at 65 ambient last flight. Still not good enough. I’m going to try the hail mary of adding the second outlet and also trimming another loop off my original spring. It’s been about 10 psi per loop.
Posted: Sat Jul 15, 2023 4:49 pm
Today with my second oil cooler exit I saw 205-208 in cruise. Was able to do 5 laps around the pattern after cruising for a half hour. Oil would get to 214 on the ground and cool to 209 on takeoff. Seems a lot better. Oil pressure is still at 60, not sure why it didn’t go down when I trimmed the original spring some more.
Posted: Sun Jul 16, 2023 11:06 am
Bryan Cotton wrote:Today with my second oil cooler exit I saw 205-208 in cruise. Was able to do 5 laps around the pattern after cruising for a half hour. Oil would get to 214 on the ground and cool to 209 on takeoff. Seems a lot better. Oil pressure is still at 60, not sure why it didn’t go down when I trimmed the original spring some more.
What make & model of oil temperature probe do you use?
Where is that temperature probe installed?
What is the make & model of the cockpit side oil temperature display unit?
Something just isn’t right here.
Posted: Sun Jul 16, 2023 12:56 pm
XenosN42 wrote:What make & model of oil temperature probe do you use?
The probe is an RTD I bought off eBay. I made my own setup with a hollow bolt and the RTD potted inside it. The instrument is a Brauniger Alpha MFD. I have not done a full calibration, but it reads ambient accurately between 40 and 90 degrees F.
Posted: Sun Jul 16, 2023 1:51 pm
by 13brv3
It would be easy enough to test it at boiling temp, which is just the temp range you need. I’m curious, what temp are you trying to maintain?
Posted: Sun Jul 16, 2023 2:28 pm
13brv3 wrote:It would be easy enough to test it at boiling temp, which is just the temp range you need. I’m curious, what temp are you trying to maintain?
Rusty,
I’d be happy if I was under 200F.
Posted: Sun Jul 16, 2023 5:18 pm
by 13brv3
Why 200? I’ve always read that you want oil temp over 212F to make sure you boil off all the water that’s collected. Does the VW engine engine need to keep the temp lower for some reason?
Posted: Sun Jul 16, 2023 6:54 pm
13brv3 wrote:Why 200? I’ve always read that you want oil temp over 212F to make sure you boil off all the water that’s collected. Does the VW engine engine need to keep the temp lower for some reason?
It gets brutally hot under the cowl - and the fuel gets vapor bubbles on the ground. The aeroinjector has no bowl so that gives us the infamous burps. So I’d rather be a little cooler.
I stretched my oil cooler bypass spring from 3 1/16" to 3 7/8", and peaked at 200F. I’m happy.
Posted: Wed Jul 19, 2023 3:50 am
In the final analysis what do you attribute your improvements to? Are the oem springs worth trying? Did you have to modify them? Curious can you replace the springs without draining the oil? I’ve had the oil drained each time I’ve pulled the springs and plungers.
Posted: Wed Jul 19, 2023 11:58 am
Peter,
Hard to say for sure, but I suspect 75% springs and 25% airflow. For some reason I can’t get my steady oil pressures below 60 psi. Someday when I have to overhaul it I’ll investigate. So to compensate I stretched my original oil cooler bypass spring and that seemed to be the final thing that got me over the goal line. I think that for most installations those OEM springs should be good. Not sure why I had high oil pressures with the springs that came in my Aerovee kit. But if your pressures are good, then there is probably going to be no change.
It’s an easy and cheap thing to try. You will lose a pint or so of oil, whatever is in the galleys above the plunger. And because of gravity that oil will go on your tools and hands. But overall it’s not a bad job.
This morning I went out to fly a couple of loops and rolls. I climbed at 80kts straight to 6000’, and topped out at 211F on the climb. Ambient was about 75F. For my acro flying I was in the low 200s and on the taxi back to the hangar my oil was 186. I feel like I won this one.
Posted: Wed Nov 29, 2023 12:32 pm
Bryan hope you don’t mind me tagging this onto your thread. Just didn’t seem worthy of a new one.
OK, Summer is gone but I’ve still been fine tuning my Sonex-A w/Revmaster. The new Rotec MKII is amazing (not for this thread though) the other pesky item has been warmer cylinders than desired. FINALLY figured it out. Yes, uneven fuel distribution was part of it - solved. Still they were not where they should have been. Making the change pictured below made a considerable difference.
For the original installation that top plate was really just a safety wire holder to keep the bottom (not shown) plate in place. But it it is clear that most of the cooling air would sneak around the side instead of going through the fins. I was unsure how much difference this would make. Now I know, it makes a lot of difference.
Posted: Wed Nov 29, 2023 2:55 pm
Brock,
Good addition to the thread I think. Can you post a picture from a wider view? I think I know what I’m looking at, but not sure.
Posted: Thu Nov 30, 2023 4:41 pm
Here are some larger pictures…
So, here is the old Intercylinder Baffle on the top. Really it was installed to hold the safety wire for the baffle below the cylinders. It’s fault is that the air is not forced through the cylinder fins.
I replaced the old with this newer version which does force the air through the fins. Not too that it is also wider (covers more fin). It is interesting that the AeroVee’s / Lycoming doesn’t wrap the cylinders yet Revmaster need it. The wrap is not shown in this pic.
Here is the template I used. I had cut a few of these and fitted them in place (just the paper) until it was right. Also note the old top baffle piece is on the lower right while the newer is in the upper right.
Posted: Wed Dec 13, 2023 10:25 am
I’m curious how others have addressed the flashing on the empi heads, between the fins etc. Also if anyone has a pic to post of what they’ve done in this regard that would be great. I’m also wondering what the factory does…I put the question to them as well. My number 3 is still hotter than the others. It’s manageable but I’d like to bring the temp down.
Posted: Wed Dec 13, 2023 10:38 am
Anything I could get with a needle file, I went after. It was not a lot.
Posted: Mon Aug 19, 2024 11:29 pm
BRS wrote:Bryan hope you don’t mind me tagging this onto your thread. Just didn’t seem worthy of a new one.
I wonder why the AeroVee doesn’t have this. The air that sneaks through the slot in the middle of the head won’t have a chance to pick up much heat, and the intake ports are right there helping to cool things off anyway. But by turning the corner it will be blowing across the fins. I’m thinking of adding this baffle.
Edit: I just cleaned out the slot in one of my new heads.
Posted: Tue Aug 20, 2024 11:59 am
Brock, your pictures look like that plate is installed on the top. That seems odd to me - don’t you want the air to go through to the bottom? Here is my current setup simulated by holding the super tin on the bottom of the head:
This is the head that has not had its center slot cleaned up yet. But once cleaned up, the air will come down through the center slot and just exit straight down. I’m thinking the original “top plate” you showed should go on the bottom, so the air coming down is deflected forward and aft to the cooling fins. Alternatively, you could set it up to just deflect air aft, since the back cylinders run hotter. The front gets plenty of cooling because the air blasts right on it from the inlets.
Any thoughts?
