Tail Skid
Posted: Fri Jan 19, 2024 1:53 pm
Does anyone know why there is a difference in the tail skids between the Waiex and Sonex nose draggers?
Assuming the pictures on the prints are to scale, the Waiex looks longer than the Sonex. The Sonex print has a dimension, but the Waiex does not.
Re: Tail Skid
Posted: Sat Jan 20, 2024 12:53 pm
by N190YX
At AirVenture, I have seen evidence of the tail skid contacting the ground while the airplane is in motion on nose dragger models, so I have thought about having a machine shop make me one where a small roller or small skateboard type wheel can be installed at the end of the tail skid. I almost cut my finger when touching the bottom of a tail skid on a nose dragger due to the roughness apparently caused by dragging the ground on a take off or more probably full stall type landing.
Re: Tail Skid
Posted: Sat Jan 20, 2024 2:13 pm
As it stands right now, I intend to use a titanium tail spring rod I have lying around instead of the skid called out in the plans. It seems to me a little “give” at that location might be better than a stiff skid.
I’m guessing the reason for a longer tail skid on the Waiex as opposed to the Sonex is the ventral fin on the Y-tail. At least, I’ve never seen the “fin” on a Sonex. There are also a lot of Waiex, Waiexes, Waiexs running around without the fin. My first copy included.
The roller is a great idea, if I can find one that doesn’t come back down when tossed in the air.
