Taildragging Conversion
Posted: Mon Mar 11, 2019 11:51 pm
by rwthomas1
Hello All,
I introduced myself in a previous post, I have an almost completed tricycle gear Sonex I want to convert to a taildragger. I have searched the forum, but not found exactly what I want, so I’ll ask.
Looking at the plans, it appears that this is relatively simple. The bottom aft fuselage is not installed yet so I have access to the interior of the tail, no problem. Order/fabricate tailwheel mount parts, and tailwheel assembly.
The conventional main gear attach to the engine mount, so that part is as simple as ordering a new engine mount, gear legs, etc.
Looking at the existing main tricycle gear mounts in the fuselage, under the seat, it seems like a bit of work to remove them, with not much to gain except loosing a bit of weight. Am I correct in thinking to simply fabricate plugs for those holes and be done with it?
This doesn’t look all that difficult, am I missing something?
Thanks, RT
Re: Taildragging Conversion
Posted: Tue Mar 12, 2019 9:11 am
Weight alone might be sufficient reason to remove the old mounts. Also cleans things up a bit giving more open area to fit other items and or storage.
Posted: Tue Mar 12, 2019 10:33 pm
rwthomas1 wrote:Hello All,
I introduced myself in a previous post, I have an almost completed tricycle gear Sonex I want to convert to a taildragger. I have searched the forum, but not found exactly what I want, so I’ll ask.Looking at the plans, it appears that this is relatively simple. The bottom aft fuselage is not installed yet so I have access to the interior of the tail, no problem. Order/fabricate tailwheel mount parts, and tailwheel assembly.
Thanks, RT
I converted mine. Left the weldments for the main gear in place. Yes weight penalty. But removing will cause trauma. I’m converting to B model and scavenged the weldments from the old fuse to give to another builder. Ended up using a grinder to cut the rivets heads. If going tri to tail, leave them in place.
Posted: Fri Apr 05, 2019 5:18 pm
by edclee
I think the main gear legs are longer on the taildragger!
Posted: Sat Apr 06, 2019 6:24 pm
by RCfly46
Yes, the taildragger legs are longer, so you’ll need new ones.
What engine are you using? I have a new Aerovee TD mount I don’t need, I’d be happy to have someone put it to good use. Shipping would be the challenge.
Joe in SE Mich
Waiex 181
Fuselage on gear
Corvair 2.7
Posted: Sat Jul 13, 2019 5:51 pm
by wav8tor
I have tricycle gear and tail wheel and motor mount. Will trade for your main gear mounts.
Mike
wav8tor@aol.com
Posted: Mon Jul 15, 2019 12:33 am
by rwthomas1
I sold most everything with the FWF package. The only thing left is the actual main gear welded steel mounts in the fuselage. I had intended to just leave them be as removing them requires drilling out rivets in a fuselage that is already painted. I know I can get them out, I disassembled a flap with rodent damage, just because. But sometimes it’s better not to mess with stuff?
Posted: Sat Jul 27, 2019 10:30 pm
by wav8tor
If you will remove the main tricycle gear mounts I will pay $100 plus shipping to Indiana
Mike wav8tor@aol.com
Phone 317-339-7781
